Since nobody has replied to your question I'll give it a shot. ASSUMING you have an alternator similar to Vans standard 60 AMP unit which is what I have, the 2 cut wires you mentioned should remain cut and not connected to anything, not jumpered together either. The remaining vertical tab connection (left side when viewing from rear) is the field connection and the color of the wire on my plug is green. The two cut wires that are not connected are colored blue and red. The output of the alternator comes off the 1/4 inch terminal stud.
I can also scan and email you Vans install drawing for the 60 AMP alternator if that would help, will need an email address.
Hope this helps.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
