Originally Posted by rv8ch
I think Van's is right - you should be able to get another half turn out of it. If you do it, and it strips, I'll send you my spare.
Glenn... if you keep taking the fitting out, clean up all of the Fuel Lube off it and it's mating part.... then re-lube it and keep trying.
Each attempt seems to take some material off, and when you clean it and try again you should get more turns for the same torque. Two or three times and it should move the 180 degrees you need...
gil in Tucson.... your TC...
PS I think I've got a spare too.... I'm going with an Andair valve...
