Old 02-04-2010, 08:50 PM
apkp777's Avatar
apkp777 apkp777 is offline
Default Highest altitude in an RV
Had someone ask me today "how high can you fly?". I told him, I have no idea. Van's lists the ceiling for an RV9 with 160 HP at 24.5k. I wonder? Some of the MEA's in the Rockies are above 14k. I know that I should have no problem with that, but it begs the question - How high have you flown in your RV?
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 02-04-2010, 09:02 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Originally Posted by apkp777 View Post
...How how have you flown in your RV?
Terry Jantzi has been to about 26,000. http://fly.hiwaay.net/~sbuc/journal/high.html
Personally, I have never been into the flight levels.
206 knots groundspeed at 17,500 in the middle of summer.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 02-04-2010, 09:24 PM
apkp777's Avatar
17.5 is pretty good. Very interesting article Terry wrote about getting to 26k. For non-turbo that's pretty good I'd say.
Tony Phillips
Old 02-04-2010, 09:51 PM
boom3's Avatar
boom3 boom3 is offline
A guy in our local EAA chapter made it to 28,500 in his RV-4.
Burrrr.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 02-04-2010, 09:53 PM
Ironflight's Avatar
VAF Moderator / Line Boy
No contest, if you include "modified" RV's....Bruce Bohanon, RV-4/8, "Flying Tiger"....49,000 and change!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-04-2010, 11:03 PM
B25Flyer B25Flyer is offline
I flew my RV-4 w/160 CS at 17 and 18K all the time.... 5gph 155KTAS. over 30 nm/gallon!!!! it was still climbing in the 500 fpm range solo...
The Rocket is still in the 7-800 fpm range at 120 KIAS between 17 and 18K... It will do 200 KTAS on 10 GPH, 20 nm/gallon, still not bad for 230 mph!!!! Put a 40 kt tailwind behind you, and fly for 4 hours and you are along ways from home!!!! I do have to watch the CHTs in the climb however, they will get over 400 very easily if you get slow or get stingy with the gas.....
The EVO would make FL 300 with no trouble I am certain... But I don't have an A-12 regulator to get there....
Tailwinds,
Doug Rozendaal
Old 02-04-2010, 11:43 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
IIRC, Kahuna got to 30k' in his super 8
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-05-2010, 07:58 AM
turbo's Avatar
turbo turbo is offline
Post did some testing..........
i did an altitude test years ago when i got a o2 bottle. 1,000fpm to 12,000' then 500 fpm to 17,999'. 180 hp 6a cs. awesome view from there. should of shut down and glided back. love them RV's. turbo
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 02-05-2010, 08:09 AM
apkp777's Avatar
Something about flying that high just makes me quiver. Thoughts of Mike Adams in the x-15 sub orbiter spinning at 230,000 while descending goes through my mind. Yeah, I am a wuss! But you can be sure, I am going to file an IFR flight plan for FL18 or FL19 in my -9. Something about reading back my clearance "climb 3000, then expect FL 18 one zero minutes after departure" that is freaking awesome. Especially when at FL 18 you tell the controller, "hey, I getting a bit of chop, would like to request higher!"
Tony Phillips
Old 02-05-2010, 08:37 AM
mburch's Avatar
mburch mburch is offline
I bet you mean FL180... even my old Subaru-powered RV-9A could make it to FL18!
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
