Old 02-04-2010, 01:37 PM
Flybuddy2's Avatar
Flybuddy2 Flybuddy2 is offline
Default Catto Prop--manifold pressure
I have a 3 blade Catto (66X76) and a standard lycoming O360A1D. I do not have a manifold pressure gauge and generally run around 2450 rpm (2500' and below). I've been averaging about 6 gallons per hour so I'm obviously running a low manifold pressure. Owned a Mooney in past with this identical engine and it would average 9+ galls/hr at about 75% power. Does anyone else have a Catto with an O360 and a manifold pressure gauge that can give me an idea of what your manifold pressure is at 2450 rpm?? thx Tom (I'm saving for a Skyview with EMS so I'm not wanting to add a gauge that I'll be taking out in a couple of months)
Old 02-04-2010, 01:50 PM
Geico266's Avatar
Geico266 Geico266 is offline
A MP gage is easy to hook up, just hook one up temporarily and use it until you get the Dynon. There has to be someone in your area that has one laying around. If you need one I got one you can borrow until you install the Dynon.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-04-2010, 05:25 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Depends on conditions, altitude etc. I'd ballpark it at 19-20 inches based on my experience with a nearly identical setup.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
