Old 02-03-2010, 06:26 PM
guccidude1 guccidude1 is offline
Default Help with finding correct 10-# for RV carbs
Sometime last year, someone posted an email quoting an engine builder saying that the correct 10-# for carbs on lycomings used on RVs is...... I have spent the last hour searching the forums using the key words carbs, carburetors, 10-# for carbs, carburetors, correct 10-# for RV carbs, carburetors, etc. Does anyone remember this post or by any chance the 10-# for sp 4-5 Marvel carb for an o-360 on a RV-9A. Thanks, Dan
Old 02-03-2010, 06:30 PM
Radomir's Avatar
Radomir Radomir is offline
10-4164 will work.. a few others too..
Radomir
RV-7A sold
Old 02-03-2010, 06:35 PM
mannanj's Avatar
mannanj mannanj is offline
Default 10-#####
It will depend on the -Dash# after the O-360. Post that number and hopefully Mahlon will jump and come up with the proper number.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 02-03-2010, 08:35 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Carb / Engine cross reference pdf
Here you go. Try this.
http://www.kellyaerospace.com/fuel_c...ebler_Carb.pdf
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 02-04-2010, 06:12 AM
mahlon_r mahlon_r is offline
10-4164-1 is common. 10-3878-M is the same thing as the 10-4164-1. 10-3878 and 10-5193 are also used. These are by far the most used carburetors on the O-360 engine.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 02-04-2010, 10:06 AM
Default RE: 10-# for O-360 carb
Guys: Thanks for the info, especially the Kelly Aerospace link. Ya'll did in minutes where I had wasted an hour with no joy. The engine was an O-360A4K (Grumman Tiger) converted to a vertical updraft -A4M to be installed on a C-172 Super Hawk. Hurricane got the airframe before install and I got the engine. Thanks again for the help, Dan.
