Old 02-03-2010, 11:07 AM
prkaye prkaye is offline
Default bleed valve
I was just looking at my bleet valve on my brakes. I just want to verify what the correct process is to open the valve in order to pump brake fluid up into them.
The valve seems to have two pieces, an outer piece that threads into the brake caliper, and an inner piece that threads into the outer piece (see photo below). The inner piece has a small hole in the middle. I'm guessing that loosening the inner piece opens the valve, allowing fluid to pass through the small hole? Is this correct?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 02-03-2010, 11:27 AM
Allan Stern Allan Stern is offline
Default brake bleed
You got it right. 1/4" wrech to open/close the valve.
Old 09-16-2010, 04:24 PM
mfshook62 mfshook62 is offline
Default Bleed Screw
How far do you open the bleed screw? If you open it up fully will it fall out or will it hit a stop, thus preventing any air leaks during the bleeding process?
Mike Shook, RV-9A, Dynon HDX,
CPI-2 Ignition, Catto Prop, EAA 124
Old 09-16-2010, 04:44 PM
Mel's Avatar
Mel Mel is offline
You only need to open it about 1/4 turn.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-17-2010, 05:27 AM
pierre smith's Avatar
Default Yes, it will fall out.
...if you want to see how the bleed valve works, just take one out or look at one at the auto parts store...it's the simplest device on your car/airplane,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
