Old 02-03-2010, 08:10 AM
bgaston bgaston is offline
Default ECI Mandatory Service Bulletin # 09-3
I'm currently flying an RV-9A with a TMX-0320 engine.
I have 320 hrs. on the engine since new. My cylinders are in the "group A" of the AD issued by the FAA. Could someone give me some insight into why the
" Mandatory Service Bulletin" only applies to engines on experimental aircraft???
Old 02-03-2010, 08:28 AM
Mel's Avatar
Mel Mel is offline
Probably because the TMX O-320 is an experimental engine and cannot be used on a "Standard" certificated aircraft.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-03-2010, 09:39 AM
mahlon_r mahlon_r is offline
Maybe because the FAA hasn't approved the repair process called out in the bulletin, to do away with the AD note requirements, for certified engines yet.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 02-03-2010, 05:03 PM
Thanks Mahlon, I think I understand now.
Old 02-05-2010, 06:42 AM
funflying funflying is offline
Default I was wondering too!
I am in group B. My ECI cylinders are boxed up ready to go back to ECI for this service bulletin "fix." The ECI rep. Joe Trampota, advised me this was my only option. Had these cylinders been in a certified aircraft they would have to be replaced. So it is very possible the "fix" has not been approved for certified aircraft. I will be interested to see what my final outcome is. The cylinders have been working fine, no indications of leaks or cracks, and they had only 220 hrs. on a TOH. What a pain but the "fix" will be at no cost to me other than shipping the cylinders back.
Pat Claar
N660PC@comcast.net
303-940-3530
