Old 02-02-2010, 02:07 PM
notworthy notworthy is offline
Default Inspection Question???
Long term lurker here asking a question for a friend...
Has anyone ever heard of a DAR requiring an initial sign off of an EAB by an A&P IA before they will do the inspection and issue an airworthiness certificate?
I have never seen this mentioned before....
Old 02-02-2010, 02:10 PM
scard's Avatar
scard scard is offline
I've been present when a DAR "requested" exactly that.
Scott Card
CMW E-Lift
Old 02-02-2010, 02:24 PM
Mel's Avatar
Mel Mel is offline
The DAR cannot legally require a A&P sign off. There was some confusion several years ago. It is now stated within FAA Order 8130.2F that an A&P sign off is NOT required. The builder must make a statement that he has inspected the aircraft and considers it to be in a condition for safe operation.
ref: FAA Order 8130.2F, paragraph 147.b.(7)
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-02-2010, 02:25 PM
N8RV's Avatar
N8RV N8RV is offline
It's truly amazing how the standards vary between DARs. I'm sure they all have good reasons.
I would've fully understood if my DAR had suggested that, since I was a first-time builder with ZERO aircraft systems/building experience, it would be helpful for us both if I had an AP/IA give the project a good once-over. And, I sort of did -- he stopped by several times and walked around, nosing here and there. Unfortunately, however, he was so blown away by how neat and clean everything looked (like most APs, he's used to working on well-worn spam cans caked in gook), that he never really delved into anything significant. He just poked around, grinning. However, a few other sets of knowledgeable eyes went over it before the DAR did his inspection.
If, on the other hand, I'd already successfully built a plane (or planes as many of you have) and had a DAR insist or even suggest that, I think I'd find a different DAR. But that's just me.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 02-02-2010, 02:40 PM
Rick_A's Avatar
Rick_A Rick_A is offline
My DAR "suggested" that I have such an entry in my log book. I was lucky in that my brother is an A&P (not IA) and he inspected my workmanship many times throughout the build process.
The first entry in my log book is Walt's professionally worded statement that he signed. One look at that by the DAR and the rest of inspection was a breeze.
The next statement in the log book is my inspection/certification statement.
So maybe not required but if you've got an A&P friend it sure won't hurt.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 02-02-2010, 02:43 PM
Rick6a's Avatar
Rick6a Rick6a is offline
You don't say much about your friend or the airplane he (or she) built. A good DAR can tell in about 30 seconds if the airplane he is asked to issue an airworthiness certificate for has been built to reasonable quality standards. Isn't possible that DAR's request was just a PC way of handling a rather "delicate" situation?
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 02-02-2010, 02:57 PM
N8RV's Avatar
That's a very good point, Rick. In fact, when my DAR stopped by a couple of months before the inspection wearing his "EAA hat", he walked around it and looked at some very specific things. Then, after looking at the engine compartment, turned to start working on paperwork.
"Uh," I said, "don't you have any suggestions of things I need to fix or change? You didn't look very hard."
He smiled and said, "As soon as I walked into the hangar and saw the plane I knew that it was well-built." Naturally, he was quite right. Of course, he still looked MUCH harder when he showed up wearing his "FAA hat".
I'm sure the DARs could all chime in on this thread and tell similar stories. You may be quite right, Rick. Diplomacy at its finest!
Don McNamara
Peoria, AZ
Old 02-02-2010, 05:00 PM
Well that may be true in some cases but this DAR has never seen this aircraft and most likely has no knowledge of it at all. This question is based on the fact that he required this signoff before looking at two previous aircraft that were showroom quality builds built by mutual friends. It appears to be standard practice for him.
The aircraft in question is not important (although it is a nice one inspected many times by an EAA Technical Counselor), it is more a question of what the true requirements are for inspection.
Old 02-02-2010, 05:54 PM
My experience with AIs for my certified airplanes is that different inspectors tend to focus on different things. It's helpful to have different qualified people looking at the plane simply because it's likely that one will catch something that another might overlook.
For a homebuilt, it's not a reflection on the builder for a DAR to ask that. It's a reasonable thing.
But if the DAR looks at an A&P sign-off and then doesn't examine the plane himself, I'd tell him to look at it himself or I'll get a less lazy one, and explain why.
David
Old 02-02-2010, 06:12 PM
Sam Buchanan's Avatar
been here awhile
David
No, it's not reasonable. Requiring an A&P/AI sign-off prior to a DAR inspection is creating regulation where no regulation exists. The rules concerning experimental aircraft airworthiness inspections are clear--requiring this "pre-inspection" is in violation of the rules.
What 'reasonable' rules should the DAR create next? The experimental community has fought several battles with rogue DAR's and much effort has been expended to make sure everyone is playing on a level field.
Please shop for a DAR and make sure you know exactly what you are getting. Most DAR's are gold but there are a few stinkers out there. Here is a good list:
http://www.vansairforce.net/dar.htm
Sam Buchanan
RV-6
Fokker D.VII replica
