You can just plug it, and drain every X amount of hours. If thats the route you choose to go I'd be interested in how much oil you collect.
I have the same set up on our -10 but I elected to run the drain down to the oil return line off #6 cyl. The belly has been completely dry, and oil consumption is less than 1/2 quart so far (10.5 hrs).
Nick "Rehab" Nafsinger
91TS Rosharon, TX
RV-4 Bought 2019
RV-10 Built 2010, Sold 2019
RV-8 SB, "Fuse in progress"
