02-01-2010, 01:06 PM
My breaker panel created with DecalPro
Here is finally my breaker switch and switch panel created with DecalPro system.
Some imperfections are visible through the high definition images (I hope the 800X600 downgrade hides them), but the overall output looks good....
Here a close up of the left part of the panel (power switches and breakers, avionics and lights):
And finally the right part:
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
02-02-2010, 07:20 AM
Looks very nice, good job. Are you, or did you already, clear-coat over the decals? If so, what clearcoat did you use?
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
02-03-2010, 08:14 AM
No. I did not use clear-coat nor plan to do it.
As far I understood, one of the benefits from using DecalPro is not being obliged to apply a clearcoat, thus allowing further expansions with minor extra-work.
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
02-03-2010, 09:09 AM
Any lessons learned with DecalPro?
In a few months I will be doing the same. Did you learn anything using it that you could share with the group? Any certain supplies you ordered, or techniques you found to help out?
Thanks.
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
02-03-2010, 09:27 AM
Thanks.
Try doing a search, there is some good info on this forum about the Decal Pro. You also might want to read my Panel Page as there are some tips on there as well.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
02-03-2010, 09:29 AM
Camillo, how do you plan for these to hold up if you don't use a clear coat finish? I have the DecalPro system, and labeled my entire panel. I found that they would scratch off with the slightest touch! Clear coat seems to be a must.
In my case, I had powder coated the panel, and the clear coat didn't stick. I had used Rust-Oleum Painters Touch Ultra Cover. I had to strip everything and start over. I now plan to sand the powder coat to take away any shiny surface. Then I will start over with all the labels, and use a polyurethatne clear coating. In my testing, the poly holds up much better. It will still scratch, but you really have to dig into to make it happen.
Anyway, that is what happened to me.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
02-03-2010, 10:49 AM
Bill - Thanks.
Your website was helpful.. Thanks for the heads up.
Wendell VAF#1832
02-03-2010, 11:42 AM
For my plane, I made decal sheets on the computer. I sprayed a clear coat over the entire decal sheet before cutting and applying to the panel. They've stood up quite well for about four years now.
L.Adamson --- RV6A
02-03-2010, 11:51 AM
Decal Pro
I'm glad someone else got the DecalPro system to work. I tried all the advise from all the websites and no luck. I was not impressed.
02-03-2010, 11:55 AM
You are right, it is a pain in the rump. It took me about eight hours to figure it out and even then I messed up a number of labels.
My problem was that I used a textured paint on my panel, thus labels/stickers wouldn't work for me. The Decal Pro worked great, once I figured it out.
Bill R.
SC86 - Easley, SC
