I searched around for guidance last year on how to do this. Didn't get much info., but enough to get me nervously started.
To aid anyone in a similar bind, here are some photos of the process that I went through.
http://picasaweb.google.com/fzvs2f under Inverted Oil System.
Following the instructions, the actual install was surprisingly straightforward. The hardest part was fabricating the hoses.
I made two new brackets for the throttle and mixture out of .05 steel sheet and attached them to the bottom of the sump. I think they will work fine. The throttle was straightforward. The mixture less so. I will post photos for these too.
Regards, Andrew Butler
RV7 EI-EEO
Galway Ireland.
