Old 01-30-2010, 11:10 AM
BGordon's Avatar
BGordon BGordon is offline
Default Oops Pop Rivet???
Just a quick question for the brain trust. I accidentally over countersunk the rear spar on the left elevator (where the trim tab mounts), the hole are to big and the standard rivets have a lot of play. I plan to run a #30 bit through and then use an oops rivet along the spar. My question comes when I get to the four pop rivets at the end of the spar. Does anyone know what pop rivet can be used with 1/8 shaft and 3/32 head.
Brandon
Brandon Gordon
KFWS, Burleson, TX
Old 01-30-2010, 01:09 PM
Skybolt Al's Avatar
Skybolt Al Skybolt Al is offline
Default Pop Rivet
The MK 319-BS fits perfect.
Al
RV-9A
Allen@AllenRice.net
Started 7/09
First flight 7/8/2015
Love this plane!!
Old 01-30-2010, 11:05 PM
GAHco's Avatar
GAHco GAHco is offline
Thumbs up The blind oops rivet is...
CR3214-4-?
The question mark is the grip range in 1/16"
The shortest they go is a -2, but the seem to work well in as little as an .050 pile-up. They are at least as strong as a 426ad3 rivet.
Tech Page http://www.gen-aircraft-hardware.com...pdf/cherry.pdf
We do have packages of both 10 or 100
To Purchase Go to http://www.gen-aircarft-hardware.com then navigate from left side box, Rivets, Blind rivets, Cherrymax, (then choose your item)
If you have trouble or questions call me Monday.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
