Old 01-28-2010, 12:27 PM
prkaye prkaye is offline
Default bleeding brakes?
I think it's time I fill my brakes with brake fluid. I understand this process is called "bleeding" the brakes. Can anyone point me to instructions on how do this? Do I need any special equipment? What type of brake fluid should I use?
EDIT - I found a thread describing how to do this;
http://www.vansairforce.com/communit...leeding+brakes
What about fluid choice? Aeroshell 41?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-28-2010, 01:06 PM
apkp777's Avatar
apkp777 apkp777 is offline
I am using Royco 782 http://www.skygeek.com/royco-782-syn...lic-fluid.html
It has a broad temperature service range.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 01-28-2010, 01:10 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Default Bleeding brakes
Your best tool for bleeding brakes is probably the search tool. Lots of posts on the subject with various methods and equipment.
Good luck.
Don
VAF #1100, EAA864
-6A bought flying
Old 01-28-2010, 01:11 PM
One thing that isn't clear to me when bleeding the brakes using this method (forcing the fluid up from the bleeder valve at the wheel... http://www.vansairforce.com/communit...leeding+brakes), should I remove the cap from the top of the brake reservoir when doing this? The cap appears to be porous, so maybe i just leave it on and air will be forced out through the cap?
Phil
RV9A (SB)
Ottawa, Canada
Old 01-28-2010, 01:24 PM
Kokemiller's Avatar
Kokemiller Kokemiller is offline
Default take cap off...
... and watch as fluid rises, you can use a 10cc syringe to remove some before overflows and it runs down the firewall.
Kelley Kokemiller
9A sb N94KK 400hrs. and counting
Barrett O-320
Catto 3-blade
Panther tail complete
Old 01-28-2010, 01:28 PM
What about removing the fittings from the reservoir on the firewall, and pumping until fluid starts pouring out of the lines here before connecting the lines back to the reservioir on the firewall?
Actually, what about disconnecting the lines at the master cylinders as well, and filling all lines with fluid prior to the bleeding procedure described above? I.e. get most of the air out directly first, and then use the bleeding procedure described above just to push remaining bubbles out?
Or would that be a waste of time?
Another question - I have all bonaco lines, so none are transparent. I won't be able to visibly check for bubbles anywhere. What have others with this setup done?
Phil
RV9A (SB)
Ottawa, Canada
Old 01-28-2010, 01:58 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Exclamation this will give a mess!!!
Hello Phil
Be carefull, you dont see the level of fluid throu the filter ... guess what will happen! You have to clean the mess on the firewall
Better is to remove the filter, place an tube adapter with the same thread, but a toube around an dack into a bottle, or take a bigger clear tube and let it stand up straight, so you can see when you reach the max. level and suck back a bit of fluid.
Be carefull when you do the other side, it will push air and bubbels up maybe.
Good luck and regards,
Dominik
Old 01-28-2010, 03:49 PM
AltonD's Avatar
AltonD AltonD is offline
I put a fitting on op of the resevoir and ran a clear hose to a bottle. I bled a pretty good amount to get all of the air out. Then I sucked out what I needed with a Turkey injector syringe.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 01-28-2010, 04:55 PM
thanks guys, all good tips.
Is a quart enough to fill a dual brake system?
Phil
RV9A (SB)
Ottawa, Canada
Old 01-28-2010, 09:07 PM
Rupester Rupester is offline
Hi Phil,
...just sent you a PM with an old post about some clever tricks for bleeding brakes. Hope they work for you.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
