Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 01-26-2010, 11:44 AM
rcfaubion rcfaubion is offline
Default Vibration with new crush plate
Made a change and looking for suggestions. RV-4, o-320, 160hp, Catto 2 blade, Landoll harmonic dampner, standard Saber alum 3/8 crush plate--ran smooth. Was looking for expanded c/g range so installed 1 3/8 by 7" steel Sabre crush plate (with new bolts) and now have a noticeable vibration in the 1100-1500 range, with a slight change at almost all other settings(imagination?) very noticeable with power off for landing.
Robert Faubion
Las Cruces, NM
N311SV RV-4 bought flying-instant fun!
SARL "Race 311"
Old 01-27-2010, 06:50 AM
n700jl n700jl is offline
Default vibration
Check the blade track and prop bolt torque. if it is out of track more than 1/8th inch. shim with heavy paper shim under the prop. 1 shim will give you an 1/8th of an inch at the tip. Use manilla folder paper for the half moon shim. if you still have vibration have prop assembly dynamically balanced to .1 IPS or less. good luck!
Jon Hubbell
RV-6 Flying IO-320X tip up 500+hrs G3X 2004 Oshkosh Outstanding workmanship award, 2004 Sun N Fun Best Workmanship 2006 Sun N Fun Outstanding Aircraft
RV-10 Flying IO-540-C4B5X 500+hrs G3X 2011 Bronze Lindy Award Winner
"Negative Ghostrider the pattern is full"
Old 01-27-2010, 08:09 AM
Default vibration
Thanks Jon, will check the track but don't think that is it. Track was fine before and just replaced thin crush plate with heavier steel plate. Had a good visit with Sam at Sabre Mfg. yesterday and he thinks it could be "sag" due to the 1/64 oversize bolt holes (can't put a 7/16 bolt in a 7/16 hole) and the much heavier weight of the steel plate so I will check that also after tracking.
Robert Faubion
Las Cruces, NM
SARL "Race 311"
Old 02-02-2010, 02:45 PM
Default update
Track is fine, dynamic balance set up for Sat.
Robert Faubion
Las Cruces, NM
SARL "Race 311"
