Old 01-25-2010, 12:03 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Best way to patch slit in FAB?
Just checking to see what my options are for a basic fiberglass question...
In order to make my FAB opening fit the cowl inlet, I had to cut a slit in the fiberglass box as per plans. I now have about a 1/8" slit about 3" tall on both sides. What's the best way to patch it up? Specifically, what's the best way to deal with the gap? Should I just add a couple layers of fiberglass on the outside of the box over the slit or should I do something to the inside of the box as well? Should I fill the very narrow slit with something (epoxy, micro, flox, etc.) before layering over one or both sides of it? I want to keep the inside profile as original as possible, and as smooth as possible.
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 01-25-2010, 12:15 PM
JonJay's Avatar
JonJay JonJay is offline
Default Layer of Glass on the outside...
A layer or two on the outside is sufficient. I did not fill the gap with anything.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
