Old 01-25-2010, 11:43 AM
corbinace corbinace is offline
Default Crank flange lug removal instructions wanted
Greetings,
I need to remove one lug from my crank flange to drill the bolt holes for mounting the LSE pickup. I have never seen this done and am loooking for the best way with no special tools.
I see one lug with a shorter shoulder that would be free quickly. I am thinking of a stack of washers around the back of the lug with a smaller washer on top and a 7/16 bolt into the rear to act as a puller of sorts.
Thanks for your help, Tim.
Old 01-25-2010, 11:58 AM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Tim,
I used an over-sized socket around the lug and a fender washer and just pull it out with the bolt as you described. Not that difficult at all as I recall.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 01-25-2010, 12:06 PM
Great!!! Thanks Pat, for the vote of confidence.
Old 01-25-2010, 12:11 PM
Brantel's Avatar
Brantel Brantel is offline
Second that method...
Socket and C clamp works for removing and installing.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-25-2010, 08:50 PM
az_gila's Avatar
az_gila az_gila is offline
Smile A big...
...6 inch C-Clamp works well as Brantel says.
Make sure that your lugs are all standard size. They do come in oversize dimensions, and a lug will be marked on the back if oversize.
Lots of dimensions, part numbers, etc. here from Lycoming...
http://www.lycoming.textron.com/supp...fs/SI1098G.pdf
If you need different bushings, call your nearest large engine rebuilder. They usually save ones from scrapped crankshafts and will have many used ones for sale.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
