Old 01-24-2010, 08:20 PM
md9680 md9680 is offline
Default Use RV-9 Tail Kit For RV-9A?
I may have an opportunity to pick up an unfinished RV9 tail kit but want to build a 9A. Is it possible to use the 9 kit but build the 9A and, if so, will Van's register me as a 9 or 9A? Thanks.
Mike Davisson
Edgewood, NM
RV-14A #140805
VS complete, Rudder in progress
2020 =VAF= donor
Old 01-24-2010, 08:26 PM
KirkGrovesRV8 KirkGrovesRV8 is offline
The tails are the same , you don't have to choose until you order the fuse.
All the Best ;-)
RV-8
RV-9 once the kids are older
apkp777's Avatar
apkp777 apkp777 is offline
Same emp kit on the 9 and 9a.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 01-24-2010, 08:29 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I believe the only difference between the tail on the 9 and 9A is the holes in the lowest rudder hinge bracket mounted on the spar of the vertical stabilizer. If you're building a 9A you use two rivets in the lower corners of the bracket. If you're building a 9 the holes will eventually get drilled for bolts, which I believe somehow attach to the tailwheel assembly.
Van's doesn't even know what you're building (9/9A) until you order the fuse kit, so they won't care. If the kit is unfinished, it is very likely that this step would not have been completed yet.
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 01-24-2010, 08:43 PM
Thanks for the quick replies! I had suspected as much but was wanting advice from those that really know. Thanks, again.
Mike Davisson
Edgewood, NM
RV-14A #140805
2020 =VAF= donor
Old 01-24-2010, 09:29 PM
bhassel's Avatar
bhassel bhassel is offline
Something tells me in the beginning there was no 9 and 9A, only the 9 and it was a nose gear.
Of course since I only have 2 brain cells left and I am saving one for retirement...I could be using the wrong one...
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 01-25-2010, 06:57 AM
Loman Loman is offline
Default More detail on TW- specific emp
Andy is correct. Those holes are for bolts that go through the aft-most F912 bulkhead and the aft plate of the WD-409(?) tailwheel spring mount. However, they are very unlikely to be drilled until the VS is being fitted to the completed fuse. Even if they have, it's not a deal - breaker. Just match drill the bolt holes to the F912 bulkhead during final assembly and put the bolts in anyway. If there are no holes, you get to drill them and put in rivets per the - A plans.
I am working from memory so check my info before relying on it.
Loman O'Byrne
RV9 TU. O-320-E2D. Engine hung, working on FWF, Arklow, Ireland
=VAF= dues paid through Dec 2020
Old 01-25-2010, 09:03 AM
Steve Steve is offline
Don't forget to contact Vans and have them assign the seller's builder number to you. They may want a letter or note detailing the specifics.
Five Sierra Fox
RV-9A
Utah
Old 01-25-2010, 05:31 PM
Yeah, thanks. I also found this in a recent RVator:
"Kit Ownership Change
When a kit, flying or not, changes ownership, please send a copy of the bill of sale (fax: 503-678-6560, mail: 14401 Keil Rd NE, Aurora, OR 97002 or email: cynthias@vansaircraft.com ), so the file can be changed into the name of the new owner. The bill of sale should include the signature of the former owner(s), serial number of the kit and the name/contact information of the new owner (i.e. address, email, telephone, fax)."
Mike Davisson
Edgewood, NM
RV-14A #140805
2020 =VAF= donor
