Is the leak at the pipe thread or the flare fitting. If it's the pipe thread, try Permatex form-a-gasket. If it's the flare, first check to be sure that both the male and female flares are smooth and not scratched. If everything looks good try putting a small drop of Locktite on the flare.
I've been following this procedure for over 35 years and never experience leaks.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
