Old 01-24-2010, 08:03 AM
prkaye prkaye is offline
Default rudder trim tab
I've heard that many builders find the need to add a rudder trim tab after test flights, to straighten-out flying characteristics.
My plane is going to be (professionally) painted prior to first flight (yes, this decision is *finally* finalized), so I'm wondering if I would be wise to fabricate and/or install a rudder trim tab now that I could bend into place as-needed after test flying. This would save me taking another part back to the painter after test flying.
Thoughts?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-24-2010, 08:18 AM
Norman CYYJ Norman CYYJ is offline
If you built the plane according to the plans you will not need a rudder trim tab.
So far I have not needed one.
Old 01-24-2010, 08:29 AM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Phil:
Many, if not most, of the RVs need a trim tab to help. Very normal unless the 9 is somehow different. If you use the Avery trim tab (which is 6 inch long wedge of some sort of composite material) you can have your paint shop paint it separately while they are painting the rudder so the colors will match. Afterwards you can tape this in place to figure how much of it you really need and just trim the wedge from the bottom up if you need it shorter. Then the only unpainted portion will be the bottom of the wedge which you can probably touch up to match. The final install can be done with something like 3M weather strip glue (the yellow sticky stuff). It will stay on, but can be removed in the future without damaging the paint underneath.
This is what I did on my -8.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
Old 01-24-2010, 08:35 AM
MrNomad's Avatar
MrNomad MrNomad is offline
Thumbs up Thanks for the simple solution that won't damage the paint
Thanks Chris.
We built our 9A according to the plans but still need a trim tab. My reluctance has been to mess up my paint but your idea of trimming from the bottom and the use of 3M makes a lot of sense.
Barry - Tucson
RV9A Superior O-360 (an amazing experience)
Dynon AP Garmin Sensenich F/P
2020 Dues paid. Thank u DR!
Old 01-24-2010, 08:38 AM
Peterk Peterk is offline
I have friends that have done both (a pre-painted metal tab that will bend and the Avery piece that Chris talks about) and no complaints either way. Chris is right, all the ones I see have some type of trim. One thing you may want to consider..I am with my 12...is that until you have wheel pants on its hard to set anything. So for now I just use my right foot.
Thanks.... this is a great solution (the avery trim tab). What sort of tape should be used for the temporary fitting? Something strong enough to hold it but weak enough to pop it off for trimming without damaging the paint underneath....
Phil
RV9A (SB)
Ottawa, Canada
Old 01-24-2010, 08:47 AM
jabarr jabarr is offline
Another option to consider--
http://www.mlblueskunk.com/Rudder_Trim_System.html
Old 01-24-2010, 08:51 AM
vic syracuse vic syracuse is offline
Super Moderator
These airplanes are all hand built, even though some are prepunched. Because of that, there will always be minor variations, and some will claim theirs doesn't need a trim tab. The reality is that any airplane will only be at perfect trim for one airpseed and one power setting. Change any of those, as will happen on climbs, decsents, cruise altitudes (yes, IAS will be lower at higher cruise and therefore less airflow over the surfaces), and you will find the need to adjust a control surface. It is also very nice to have the adjustable trim on the rudder for those long descents from the high cruise altitudes. It is also very nice to be able to trim the wings level when the autopilot is engaged thru the use of an adjustable rudder trim. Is it absolutely necessary? No. But it sure is nice to have.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 01-24-2010, 08:54 AM
Very interesting! That looks like a really nice arrangemnet! I have Vans' aileron trim, and if I put in this rudder trim it could be really nice on long x-countries (since I don't have autopilot). Anybody used this system that can vouch for it?
Phil
RV9A (SB)
Ottawa, Canada
Old 01-24-2010, 09:52 AM
CNEJR CNEJR is offline
Default I know a number.....
of people who have used Blueskunk trim, seems to work well. I did one similar to his, his I think works better. You can't beat the price or quality.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
