I just bought another one to replace the broken one I found during annual. I'm 99% sure that the "non-AP" version is for an engine with standard carburetor. The Airflow Performance setup does not attach to the engine the same way, so the top plate of the FAB is different.
TIP: I just replaced the top plate on mine at about 350 hrs after it broke in two from vibration. One way to forestall that problem is to upgrade the top plate to 0.090" thick plate, instead of .063 that is standard from Van's. Airflow Performance might actually have them pre-cut for you, or you can always get some plate and make your own.
The other way to forestall is to make sure your clearance from the FAB inlet to the cowl is sufficient (i.e. some say a full 1"). Reference following
thread for more discussion.
