Old 01-23-2006, 08:02 PM
Jamie's Avatar
Jamie Jamie is offline
Default Brass Fitting for Brake System
I'm putting in my brake system and I have a question regarding the proper installation of the brass fittings on the plastic lines. Obviously I'm to put the nut and sleeve (in that order) onto the tubing, then insert the brass insert into the tubing. I guess my question is...how far forward should I pull the nut and sleeve? Should I bring it just up over the insert or should I bring it all the way to the end of the tube?
Old 01-23-2006, 08:09 PM
DGlaeser DGlaeser is offline
Default Brake tubing
Slide the tube/insert into the fitting as far as it will go, then slide the nut/sleeve down and tighten the nut.
Dennis Glaeser
7A Fuselage
Old 01-23-2006, 08:28 PM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Default More info
I think your original question was unanswered. It is correct to put the inner sleeve as far into the tube as it will go. (The flange will serve as a stop) As far as the ferrule goes, after you place the nut and the ferrule onto the line, just slip the line as far into the fitting as it will go, then when you slide the ferrule and nut up to tighten them, it should place the ferrule approximately 1/8-3/16" back from the end of the line right over the inner sleeve. The nut then working with the fitting will properly lock the ferrule onto the line. Hope this helps.
--hawk
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
Old 01-24-2006, 05:17 AM
Jamie's Avatar
Excellent, guys! Just what I was looking for.
Thanks!
Old 01-24-2006, 11:34 AM
Davepar's Avatar
Davepar Davepar is offline
Heating up the end of the tube in a cup of hot water makes the process much easier. Also be sure to check that the sleeve doesn't carve out a flap on the inside of the tube. I'm not sure if that can happen with this tubing, but it doesn't hurt to check.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 01-24-2006, 12:00 PM
mgomez's Avatar
mgomez mgomez is offline
I used a heat gun (rather than hot water) to soften the tip of the tubing. No matter how I did it, it took a great deal of effort to get the thingy inside the tube, and then to slide the ferrule over the tube. Some tapping was required!
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 01-24-2006, 12:10 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default tube
Strange - mine went right on. I wonder if that's because my shop is currently about 35?F. Hope I did it right. I'll check it again before I start pumping in the brake fluid.
Mickey Coggins
http://rv8.ch
"Hello, world!"
