Hmph. Cracked the slider frame.
It's always that last little bit that gets you, you know? The slider frame was off ever so slightly, so I thought I'd fix it. I sure did - I cracked the tubing on the rear bow right at the top, next to the weld.
Anyone know if this is something easily welded, and if so, will it disfigure the canopy due to different dimensions on one side vs. the other?
Alternatively, anyone seen an open cockpit RV-6A before?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
