  #11
Old 01-23-2010, 07:09 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
After washing it out, I would flood the area with WD-40, followed by Boeshield. The WD-40 disperses water and the Boeshield is great corrosion protection.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 01-23-2010, 10:31 AM
rv72004 rv72004 is offline
I would high pressure clean with water. Blow dry, and spray with any good protective oil.
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 01-23-2010, 05:47 PM
n180tf n180tf is offline
Default Another idea
My friend Bob recommends Patrick at Crankcase Svcs. for this kind of thing.
Old 01-23-2010, 07:18 PM
decathlon737's Avatar
decathlon737 decathlon737 is offline
Dude, some things you just clean up and don"t tell your friends about .
Bill Woods
RV8 sold 180 hrs. of pure joy
(Nov 2018) Bought 7A Tip up
project, converting to tailwheel
slider (just because)
Thunderbolt YIO390
Hartzell BA
Steinair Panel (WOW)
Old 01-23-2010, 09:02 PM
Bullseye's Avatar
Bullseye Bullseye is offline
I personally won't admit in public how true this statement is...
Andrew Z.
Engineering Flight Test Pilot/Engineer, CFI-A, CFII, ATP
RV-7 in work (See my build log.)
Empennage...Done (except rebuilding the rudder.)
Wings...Halfway complete.
2018 Dues Paid
Old 01-24-2010, 04:40 AM
PIN 37 PIN 37 is offline
Bernie
Clean up and build on, there is not much of a problem with corrosion here in Oz. pm me if you want to talk about it
cheers
Phil
Old 01-25-2010, 06:44 AM
Bernie RV7 Bernie RV7 is offline
Heres what I did after all your suggestions .... Soap and water then high pressure wash and dry with shop air a couple of times and then WD40
TKS
Bernie Flying RV6
Melbourne Australia
Old 01-25-2010, 06:57 AM
DakotaHawk's Avatar
I guess you won't be needing my dog then?
Scott "Grumpy" Stewart
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 01-25-2010, 07:04 AM
Geico266's Avatar
Geico266 Geico266 is offline
I can see some "cool" tail art in your future!
Maybe you can get Baskin Robbins to sponsor you!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 01-25-2010, 07:57 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Does this need to be moved over to safety? I mean really, should we be consuming food products in the shop area? What if one mistakes proseal for chocolate syrup for your ice cream? This food (and beverage!) in the shop thing could be a real problem!
Bryan
Houston
