Originally Posted by PIN 37
Same question here.?
You can build a glob of flox on the inside of the fairing near the rear split and then use a stainless sheet metal screw (tapping thread) to hold the rear tightly together.
The top fairings required two screws, one in the cabin floor and one in the wing fairing. Once you get it built, use your fingers to find the places that hold the fairing tightly in place.
On the lower intersection fairings, I did not glass my fairings on. This is because I looked at the pictures in the construction manual and did not read a single word....
. The pictures show attachment with nutplates and construction of a faired "pocket". Its fine. I do not like the vertical split method. Seen plenty of poor fitting fairings done that way. I like the rear split much better. There is a technique to glass the whole intersection fairing to the nose fairing and maintain the rear split. I may do that some day but it is WAY down the list of priorities.
