The general aviation community has been requesting a product with the same geometry as a standard PAR-36 lamp. Other options are available, but cannot be installed without major modification to existing mounting brackets and hardware. The new Whelen Parmetheus? is currently the best solution available in a direct fit replacement for existing 100W PAR-36 lamps. It utilizes the same construction and technology that is used on the landing and taxi lights Whelen has certified for the Gulfstream 650, Hawker 987 series jets, Sikorsky & Bell helicopters.
LIST price $475, available factory direct for $399. Product available to order this week via web portal. Deliveries beginning end of March.
http://www.whelen.com/pb/Aviation/Pr...heus_Flyer.pdf
How bright are they.....
GE publishes 110,000 candelas for the 4509 lamp. This is skewed due to the fact that amount of light is in a very small ?cone?, and severely degrades over a very short period of time. Internal Whelen testing has indicated, out of the box, some lamps produced only 88,000 beam candela, and all showed approx. 20% decrease in light output within 10 hours. The GE 4509 is rated at 25 hours LAB Life. The new Whelen LED landing light produces over 20,000 hours of consistent light output exceeding 40,000 beam candela and produces a much larger cone of visible light further increasing the level of safety. Also available as a taxi light as well with 13,500 beam candella.
Jeff Argersinger
Whelen Engineering
