01-19-2010, 09:39 AM
soft alum rivets
Over the weeking I was getting ready to fit the two halves to my cowling when I realized I need to order the required "soft" rivets. I understand I'll need two sizes , does anyone have the proper numbers for these??
Went on to Vans site and only found "AD"'s, it is my understanding that I'll need "A"'s (soft) am I wrong ?
Bob
01-19-2010, 12:09 PM
Correct, you want 'A' rivets. More specifically:
AN426A-x-y (or MS20426A-x-y)
where x=diameter in 32nds
and y=length in 16ths
'A' == 1100 aluminum (soft)
'AD' = 2117 aluminum
more info at: http://www.gen-aircraft-hardware.com...olidrivets.pdf
Aircraft Spruce and Genuine Aircraft Hardware carry them.
Edited:
Doh! Cowling..........the critical word here is cowling. As Scott McDaniels says below.......soft rivets are not called out on the cowling. AD rivets work fine on the prepreg (epoxy) cowling.
Steve Allison
RV-6A - sloooowwww build
First flight - 3/8/14
Phase II - 5/19/14
01-19-2010, 03:00 PM
Are these rivets called for in the plans? If so why doesn't Vans supply them? Or is this a change you are making?
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
01-19-2010, 03:27 PM
[quote=Stevea;398097]Correct, you want 'A' rivets. More specifically:
QUOTE]
Not correct.
The AD rivets work just fine in the prepreg (harder material) cowling. That is why "A" rivets are not supplied nor are the called out in the plans.
Scott McDaniels
Hubbard, Oregon
01-20-2010, 06:42 AM
Moderator/Tech Counselor
I used the normal AN rivets in my prepreg cowl and had no issues squeezing them into counter sunk holes. I countersunk a little extra and was able to easily bury the heads for a nice, clean resolve. None ever loosened in the five years I owned the plane. I never saw any notes on using any alternative or soft rivet.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
01-20-2010, 09:41 AM
Wow! Thanks everyone, good catch , Here is what happened.The original cowling was the "old" style and used the "soft" rivets,this is being replaced by the "new " style cowling , but I didn't realize that the rivet requirements would change.
Thanks for catching my mistake.
Bob
01-20-2010, 09:48 AM
Bob
I used standard AD rivets in my "old" cowling and 17 years later they still look great.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
