Old 01-18-2010, 03:48 PM
JetMech72 JetMech72 is offline
Default Aileron practice kit question / clarification
I just finished drilling the skins and the trailing edge wedge, next comes the dimpling and countersinking. Here is where I am confused:
"(Dimpling the spar is a special case. It is 0.040" thick - a bit thick to dimple well and a bit thin to machine countersink safely. So, we combine methods by dimpling first, then enlarging the dimple with the hand deburring tool. This is done by eye and tested by dropping a rivet in the hole to determine fit.) Machine countersink the spar and trailing edge wedge with the microstop countersinking tool."
The first part says the spar is too thin to machine countersink safely, but the second part says to machine countersink the spar. Which is it?
Preview plans...check
Tool kit...check
Practice kit(s)...finished
Empennage kit...started!
My KitLog
Old 01-18-2010, 03:54 PM
Jamie's Avatar
Jamie Jamie is offline
What they mean is that the spar material is too thin to simply countersink so that a rivet would sit flush...so they have you dimple it and then just "touch" it with the countersink enough to make a rivet sit flush.
Old 01-18-2010, 06:44 PM
So I just dimple it and lightly use the countersink tool and bypass the hand deburring tool altogether?
Tool kit...check
My KitLog
Old 01-18-2010, 07:01 PM
apkp777's Avatar
apkp777 apkp777 is offline
Debur then Dimple then machine countersink. You should always debur all holes before dimpling (IMO). That method is only used on thick material like the spars. By dimpling first you will avoid a "knife edge" that would be produced by machine countersinking only.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 01-19-2010, 08:26 AM
Gotcha.
Thanks!
BTW I do deburr all my holes
Tool kit...check
My KitLog
