01-18-2010, 10:43 AM
Cutting holes in fiberglass
I'm ready to install strobes/navigation lights in my fiberglass wingtips. I need to drill/cut a 1 1/2" and a 1" hole.
What tool should I use to cut these holes without chipping the fiberglass?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
01-18-2010, 10:45 AM
probably the cheapest method would be to get a high rpm pencil grinder and some rotary carbide grinders and go to town at high speed.
i've seen the pencil grinder at harbor freight for something like 20 or 30$, pretty cheap. pencil grinder http://www.aerocraftparts.com/Catego...b-843f158a90b7
bit
http://www.aerocraftparts.com/ItemFo...a-76c5740e05e3
you can get cheaper bits, but perma grit is pretty nice.
nothing special here...
01-18-2010, 10:55 AM
I think a conventional hole saw would be a good choice if the glass is in good shape and you go at it slowly.
01-18-2010, 11:11 AM
I like the Dremel diamond wheel for fine cuts in fiberglass. You can cut right next to your scribed line.
diamond wheel
01-18-2010, 11:14 AM
I cut mine with holesaws, then used a Dremel to smooth up the edges. No problem.
William Slaughter
Houston, TX
RV-8QB
01-18-2010, 11:57 AM
I mark the hole with a sharpie, drill a series #40 holes about 1/16" away from the cut line, use a dremel tool cutoff wheel to finish the cut between the #40 holes, and finally sand back to the cutline with a dremel tool sanding band.
Sam Ray
01-18-2010, 12:17 PM
For curved cuts I find this works well:
Drill a hole or multiple holes then use an ordinary fret saw for the initial rough cut followed by filing and sanding to the final shape. Did my wingtip landing light cut outs and spinner prop cutouts recently this way.
The sanding drums/sanding bands that Avery sell work well, especially in a pillar drill if it suits the workpiece
http://www.averytools.com/pc-807-39-...ing-drums.aspx
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
01-18-2010, 12:21 PM
If you want a perfectly round hole, just use a hole saw. Covering the fiberglass with masking tape would help with any chip out, although there shouldn't be much.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
01-18-2010, 12:24 PM
Hole saw.
Hole saw, takes a few seconds, no chipping! You should have a "set" of various dimensions handy anyway, to make lighthening holes, etc.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
