Originally Posted by hgerhardt
Really? You can't trust an AN 1/4-28 bolt with an AN pinched locknut AND red "permanent" Loctite to hold a 1-lb load on the back of a 3-1/2" diameter plate that's around .200" thick, held on by 5/16" studs that used to hold a magneto? Wow, you're a he!! of a worry-wart. I'd be WAY more concerned with the cylinder base nuts and the connecting rod nuts not being safetied, for instance.
Roger that, I am a worry-wart. The cylinder base and connecting rod nuts are required hardware. There are lots of options for mounting ignition coils.
