Old 01-16-2010, 08:40 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Default Alternator mount bolts?
This seems like a dumb question, but I have to ask anyway
I decided to use an 87 suzuki samurai alternator on my build, and I'm trying to figure out which bolts are used to mount it. The bolt holes on the alternator measure .335" or 8.52mm. An 8mm bolt (.315") seems a bit sloppy. Does someone make an 8.5mm bolt? Or 21/64"?
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 01-16-2010, 09:30 PM
rocketbob's Avatar
Why not make a thin sleeve bushing so you can use a 5/16" bolt? Or just drill out the mounting holes to 3/8"?
My experience with these alternators is the bolt holes will elongate if they're loose.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-17-2010, 05:47 AM
turbo's Avatar
turbo turbo is offline
Post alternator warranty?
andy, i have been using the 87 suzuki alt for 10 years. been thru a bunch of them. it had a life time warranty back then. what kind of warranty did you get on the new one?
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 01-17-2010, 06:03 AM
Lionclaw's Avatar
Lifetime as well, from Autozone. Do you recall what size bolts you used?
I was hoping to not have to modify the alternator. It would be nice to just be able to pick up a stock unit if I'm out somewhere and install it without having to modify it first.
Old 01-17-2010, 11:10 AM
turbo's Avatar
Post alternator
i am out of the country now but dont recall a problem with bolt size. get the largest that will fit then crank em down. the metal insert in the alt bracket will help secure the alt when tightened. the right smallest size belt will keep the alt from hitting the cowl. turbo
Ed D'Arcy
