Old 01-15-2010, 12:20 PM
larrynew's Avatar
larrynew larrynew is offline
Default Competition: Practice Tool Box Tools Required?
Tomorrow, our EAA Chapter will be assembling 2 practice tool box kits (donated by Van's, THANKS VAN'S!) in a side by side judged competition with the winning team getting lunch at the local catfish restaurant.
It's been over a year since I built mine and I want to make sure I bring enough tools without bringing everything I have. What would be the minimum list of tools (2 of each) to complete the practice tool box kit? Anything I've forgotten?
I've got:
Drills with bits
Deburr tools
Manual squeezers with dies
Cleco's with pliers
Snips
Emory Cloth
Files
Pliers to bend wire handle
Do I need rivet guns or will manual squeezers get all the rivets?
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 01-15-2010, 12:36 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Default It's been a while...
-Squeezer wont get all the rivets. I used rivet gun and back rivet plate on some.
-Hacksaw to cut wire handle
Don
VAF #1100, EAA864
-6A bought flying
Old 01-15-2010, 12:54 PM
FresnoR's Avatar
FresnoR FresnoR is offline
I just finished my tool box. The four flush rivets on the bottom of each side cannot be reached by a squeezer. There is also the handle on the top that requires two rivets on each of the brackets, this also requires a gun or C-frame.
-Bring a couple clamps as well.
-A Small ruler will help get the handle placed properly in the middle.
-The hindge part can be tricky and it is not explained well.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 01-15-2010, 03:23 PM
rvbuilder2002's Avatar
[quote=FresnoR;396939]I just finished my tool box. The four flush rivets on the bottom of each side cannot be reached by a squeezer. There is also the handle on the top that requires two rivets on each of the brackets, this also requires a gun or C-frame.
QUOTE]
I believe these four rivets can be reached with a squeezer that has a 4" yoke. If you only have a 3" yoke you will have to drive them.
Scott McDaniels
Hubbard, Oregon
