Old 01-13-2010, 12:31 PM
Darren S Darren S is offline
Default Van's wiring harness - schematic
I am building a -7 and am thinking of buying the Van's wiring harness for $350. It is item : Two place wiring harness kits: ES WH 6/7/9 KIT.
Does anyone know where I could look at the wiring schematic to see if it will fit my needs ? Their site doesn't show anything.
Darren
Old 01-13-2010, 02:46 PM
Skint Skint is offline
Default Wiring Harness
I used Van's wiring harness and, as I was told later, its a good place to start. You will find you will be running many other wires also. For example, if you put strobes on your 7 thats not on Vans, auto pilot servos not on Van's, ( and beware of insufficent grommets in the wing ribs to carry all the wires before you close em up)
I should have planned better what equipment I was going to have and then wired accordingly......then added some extras!
Tim Bennett
RV7a
135
Polished aluminum
Painted wheelpants and fairings
Still have not developed a liking for fibreglass
2014 dues paid
Old 01-13-2010, 07:37 PM
rvbuilder2002's Avatar
Not true.
The wiring harness accommodates nav. lights, strobes and landing lights.
It does not accommodate auto pilot (the requirements very from one brand to another).
Scott McDaniels
Hubbard, Oregon
Old 01-14-2010, 08:51 PM
You can buy the OP drawing from Van's. I can't remember the exact number, though -- OP-28 maybe. Should be able to find it at the company store.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 01-14-2010, 10:18 PM
aturner's Avatar
aturner aturner is offline
Unless I missed something big, Van's harness accommodates lighting, but does not include any of the wing wiring or high voltage strobe leads. This question was confusing to me, as I purchased the harness when finishing the wings, only to find out upon delivery that it contains just fuselage wiring.
-Andy Turner
RV-10 N784JC
Old 01-15-2010, 10:43 AM
The Harness kit does come with extra wire in the common gauge sizes for doing the routing through the wings for the landing lights, nav. lights, etc.
You are correct that it does not come with the high voltage cables required for the strobes. Their are a lot of different strobe configurations available (remote supplies in the wing tips, central supply with cables leading to each strobe tube, etc) so the cables have to be done separately depending on the system you choose.
Scott McDaniels
Hubbard, Oregon
Old 01-15-2010, 02:46 PM
AirbusPilot AirbusPilot is offline
don?t buy it.
I ended up trowing away and I did a complite new installation.
Spend the money in wire and circuit brakers
Also buy bob nuckell book
Just my 2 cents
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 01-15-2010, 03:18 PM
jthocker's Avatar
jthocker jthocker is offline
Originally Posted by AirbusPilot View Post
don?t buy it.
Just my 2 cents
As usual I will dispute that there is anything wrong with Van's harness and schematic.
I've used them for the last 4 airplanes, and have had great success using them as a basis, and then modifying them slightly to accommodate particular needs.
My 2 cents,
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 01-15-2010, 03:41 PM
Isaac's Avatar
Isaac Isaac is offline
Default RE: Van's Wiring Harness
I bought the wiring harness kit but wound up using very little of it. If you are doing a very basic electrical system then the Van's wiring kit might be practical but I am of the same opinion as Fernando "save your money and buy wire and circuit breakers and get Bob Nuckoll's book for guidance". I did find that the OP drawing was a little bit helpful as a reference. Just my opinion so ...
Old 01-15-2010, 05:20 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I agree with the idea if your system is simple, the Van's kit is fine. If you are going with a lot of fancy lighting, radios and analyzers, do your own buying. I did much more than the kit covers and needed more wire and other items like CBs and terminal boards. The big trick is to plan ahead, as suggested, and try to incorporate your electrical system into the plane as you progress in the building. It is easier to run wires and set things up before parts of the plane are closed up. Do a simple schematic and include everything you plan on installing. Having the equipment in hand will aid you in determining wire and CB requirements and how certain things can be mounted.
I used the kit in my 7A (came with FWF kit) and the components were good and the premarked wires were helpful. I used what I could and suplemented what I needed extra. The OP that Bob mentioned is a good, basic schematic and can help in the planning.
Have Fun
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
