01-12-2010, 08:31 PM
which sealant better (or best) for airbox filter?
For 0-320 FAB installation, the filter needs to be notched to fit over the carb's accelrator pump. Van's FWF instructions indicate that RTV silicone can be used to fill in the resulting gap between the filter and pump.
Of the two below, which would be more appropriate for this application. One, is specifically listed as a high temperature (500 degree) RTV silicone. The other is a higher temp gasket sealant (rated for 600 degrees):
Permatex? Hi-Temp RTV Silicone Gasket Sealant
http://www.permatex.com/products/Aut...et_Sealant.htm
Permatex? 1372 High Temperature Form-A-Gasket? Sealant
I'm particularly concerned about any possibility of a small portion of sealant breaking off and being sucked into the carb. I assume that would not be good. However, that Van's calls for it to be done this way, I take it that it's not a significant issue.
Any idea which of these (or something else entirely) might be better?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
01-12-2010, 09:31 PM
Sealant
I too am extreemly concerned with silicone flaking off and being sucked into places it doesn't belong. I have seen silicone strings and globs caught in oil filters in auto engines where it was used as gasket material.
If properly done and installed on clean, dry aluminum intakes, the risk should be minimal. Just make sure that you prepare the surface according to mfgr's instructions.
There can be absolutely NO  and I repeat NO  oil on the surface that the silicone is applied to. Otherwise it will peel, slide, flake or slip off what it was applied to.
I like Pro-Seal better.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
01-12-2010, 09:35 PM
what happens when the filter needs to be changed?
Does the sealant have to be re-done at every filter change?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
01-13-2010, 11:30 AM
Use a different K&N filter
Please search the archives for my posts about this. Using the K&N website I found a filter that has a larger ID than the one Van's supplies. Its CFM rating is just a few percent less. I am at work and can't remember the part no. The one I use can be snaked around the accelerator pump well without modification. The ID of the Van's supplied unit is dimensionally SHORT of conforming to the oval perimeter. The one I use slightly overhangs the metal plate but fits inside the FAB just fine.
LarryT
01-13-2010, 12:11 PM
No, this filter is designed to be cleaned, not discarded, with cleaning kits available at auto parts stores.
Steve M.
Ellensburg WA
01-13-2010, 12:12 PM
I would guess it depends on size, but what would be the range of consequences for a piece of RTV or proseal (being used to seal the gap around the accelerator pump) being sucked into the carburetor?
Steve M.
Ellensburg WA
