Old 01-12-2010, 04:54 PM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Default Tips on using the 7.9mm (.311) Reamer
I'm about to use my new reamer from Averys to drill the hole in the landing gear mount and legs. Any advice before doing so?
Smitty
Old 01-12-2010, 05:37 PM
Danny7 Danny7 is offline
general reamer usage:
fast feed speed (push it as fast as you can), moderate rotation speed (don't have it spinning at 10000 rpm. much slower is better).
use lots of cutting fluid
reamer should only be used for final sizing, Not "drilling". drill everything in alignment with undersized drill bit, ream to final size
edit: from avery's web page: TIP: Drill holes 1/32" undersize & use reamers for perfectly round holes & close tolerance fits on critical holes where you want a tight or snug fit of the fastener.
nothing special here...
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Drill the holes to near final size first (if they're not already). Do your best to make sure you are properly aligned, use moderate speed and plenty of lube. Plenty of lube.....Plenty of lube.....
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 01-12-2010, 05:53 PM
rocketbob's Avatar
and don't reverse the reamer, it will quickly dull it.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-13-2010, 08:04 AM
Tumper's Avatar
Tumper Tumper is offline
Default Me too
Drill on brother, and get good at it so you can help me...
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
