Old 01-12-2010, 10:09 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Question Split cases Lyco O-360
Dear Lyco experts,
I'm working on disassembling an O-360 Lyco and been told I'll need a special tool to split cases. Anyone know about this and if true can you point me in the right direction?
Many Thanks,
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 01-12-2010, 10:39 AM
rocketbob's Avatar
What I do: I have a tool I made that screws onto the thru-bolts and I hammer them thru the case. Once those are out I'll then CAREFULLY hit the case with a dead-blow in the accessory case area to get the case halves started loose. Then pry apart with pieces of wood or plastic. As long as you're careful you don't need the tool. The thru bolts will have to be removed regardless to check fit, so I feel it makes more sense to do it from the get-go.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-12-2010, 11:41 AM
Thanks Bob,
How tight are the thru bolts usually? Can one install a couple of nuts and tap out with a wood mallet for instance? I can make most any jig or tool if I have an idea what it's like...
Jerry Cochran
Sherwood, Oregon
Mark Twain
Old 01-12-2010, 12:06 PM
rocketbob's Avatar
depends... IIRC they are a 0.000"-0.002" interference fit. If the fit is 0.002" it will take some pounding to get them thru, and a wooden mallet won't do much good. They are tapered in the middle and only engage the case for 2" or so the last bit you have to hammer with a brass drift.
N8155F C150 flying
Old 01-12-2010, 12:13 PM
MikeT MikeT is offline
Default Splitting cases
An easy way to get the through bolts out is slide a couple of 1/2 inch drive deep well sockets on the stud, you have to figure the correct combination to get the desired length, then a washer and nut. Tighten until the bolt comes out. You have to change the combinations of sockets a couple of times to get it all the way out.
Some engines have a case bolt behind the camshaft gear, don't forget to take that out.
Old 01-12-2010, 12:52 PM
Vern's Avatar
Vern Vern is offline
Default Lycoming rents case split tools...
...Thru their dealers. Takes about $1500 deposit. It's two heavy 1" steel plates, nuts, bolt extensions,etc. Procedure is shown in the manuals.
It's still a pain!
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
