Old 01-11-2010, 10:05 PM
DaAV8R DaAV8R is offline
Default Rudder Pop Rivets
The leading edge of the -8 Rudder uses AD-41-ABS pop rivets. One section of my leading has a small gap between plys. The gap is on the underneath side and the exposed joint is good. The AD41ABS snaps before the plys are in full contact. Would a AD41BS with a steel shank have more pulling power and therefore be more likely to pull the plys into contact before setting?
Thanks.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 01-12-2010, 06:38 AM
flion's Avatar
flion flion is offline
In my opinion, probably not. The pop rivet will swell first and, once it has swelled to fill the drilled hole, any gap at that point will not completely close. From what you described, you probably don't have a problem. It's not structural and it's generally hidden once the surface is hinged. However, the way to deal with it is to use long reach C-clamps to close the gap before you pull the rivet.
EAA Technical Counselor #5357
