Old 01-10-2010, 08:07 PM
Skint Skint is offline
Question Electric primer installation
Having received my electric primer kit from Van's, there really is little guidance on the installation ie make your own bracket, wiring to panel etc
So where is a good place to place the solenoid? This would be for an 0-360, carb, 7a set up.
Looks like some angle attached to the firewall then there are threaded holes on the bottom of the solenoid to attach to the angle. I would assume a bunch of adel clamps to support the tubing runs and a push/start switch on the panel.
Guidance please!
Tim Bennett
RV7a
135
Polished aluminum
Painted wheelpants and fairings
Still have not developed a liking for fibreglass
2014 dues paid
Old 01-10-2010, 08:45 PM
apkp777's Avatar
apkp777 apkp777 is offline
I used a straight (steel) fitting and connected it to the gascolator. Looks good. Others have done the same.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 01-10-2010, 09:08 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Default switch
With respect to the switch if you have the boost pump you can wire to a 2 position switch where the 2nd position is momentary so you switch on the boost pump then hold the switch for a few second to prime. I have my switch between the throttle and mixture so it can be reched while holding the throttle.
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
