Old 01-10-2010, 09:48 AM
deanm deanm is offline
Default engine sump heaters
Bought Pma like new reiff heater thanks for all the replys
Old 01-10-2010, 12:46 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I would not use a light bulb. I believe I currently have an old (worn out?) Reiff silicon(e) pad sump heater. I just ordered another from Wolverine which I will add soon to see how it works.
Bottom line, I am a firm proponent of a permanent sump heater.
Old 01-10-2010, 06:24 PM
N941WR's Avatar
N941WR N941WR is offline
Dean,
Try doing a search. This topic comes up every winter. There is a lot of info already out there.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-10-2010, 06:25 PM
Bushcaddy Bushcaddy is offline
Default Wolverine...
I agree with Ron...Wolverine is an excellent low cost alternative to something else that says "Aviation" on it: http://www.wolverineheater.com/products.shtml
Don...
Plymouth, MA
Varga 2180; N2C
http://www.n2charlie.com
2013 Donation Made
Old 01-10-2010, 07:15 PM
You-all can do as you like but, it was -10F in our neighborhood this morning and when I checked the oil temp and cht of my trusty Lycoming, it was 87F/76F respectively. That's with 4 rings and one sump strip of the Reiff type. Also, based on a report in a well known aviation magazine, the humidity inside the engine is down around 15%. These heat systems do dry out the engine.
The oil temp is measured up at the filter and it is an indication of how warm ALL of the engine is. I have no heat in the hangar and at 300 watts, this is a good deal and good for the engine whether you can fly or not. Why go chincy on something as important as preheat?
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 01-10-2010, 07:25 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
I just bought two of the stick-on type 50-Watt Kats heaters. I bought each for about $15 on Amazon.com, and shipping was free, I believe. I spliced them both into a single plug so I wouldn't use up another outlet.
This morning I went flying...ambient temps were right at 32 F. After starting the engine, it took about 2 minutes to register above 70 F on my oil temp gauge. The last time I did that without the heaters it took closer to 8 minutes and I could hear the oil pump cavitating! I'd definitely recommend heat of some kind.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-10-2010, 10:12 PM
Originally Posted by Carl J. Niedermeyer View Post
Sonny
Just out of curiosity, were you using a single weight or a multi-vis oil?
Hi Carl,
I suppose that's a very fair question! My ECI 0-360 calls for Phillips X/C 20-50.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-11-2010, 06:02 AM
pierre smith's Avatar
Default I'm with David on this one...
I installed the Reiff two pad system on my -10 and bought a timer and set it to come on at midnight Friday. I cranked her up at 10:00 a.m. Saturday and the oil instantly registered 80 degrees, with the OAT at 19deg.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-11-2010, 01:02 PM
dadroot dadroot is offline
Check your 'NAPA' store. Search for oil pan heaters.
Tommy Rutherford
Grumman AA5 N7351L
RV9A N924TR(reserved)
Old 01-11-2010, 06:18 PM
Greg Arehart's Avatar
I installed both a pad heater and Reiff cylinder heaters. Even though it's not that cold in Reno, it sure is nice to call my hangar a couple hours before a flight and arrive to an engine that is 100 degrees all around. Never a problem starting!
greg
Greg Arehart
N 7965A
