Old 01-09-2010, 06:21 PM
prkaye prkaye is offline
Default manual aileron trim
I misplaced my instructions for installing Vans' manual (spring) aileron trim. However it looked pretty obvious so I installed it the way it seemed to make sense.
One question though... is the white trim handle supposed to move back and forth as you deflect the control stick left and right? The springs pull the white handle around as I move the control stick...
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-09-2010, 06:28 PM
Not if it is like the manual trim on my -6. If the trim handle moves, you need to tighten up the UHMW block that holds the trim handle so there is enough drag to hold the handle still when you move the stick.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-09-2010, 06:29 PM
noelf noelf is offline
Default It sounds like...
...you need to tighten up on the friction bolt. The intent is that when you move the manual aileron trim lever, you "bias" the force on the stick.
As you move the trim lever, the stick should move. When you move the stick, the trim lever SHOULD NOT move.
Old 01-09-2010, 08:33 PM
Thanks guys! I just took it apart and widened the slot in the friction block so it could clamp tighter around the shaft of the handle. Seems to have done the trick.
Phil
RV9A (SB)
Ottawa, Canada
