Many have done this -
When you get a quickbuild kit and want a flop tube, you have to do this.
I took the right tank off, cut a hole in the rear face of the tank in the second rib bay to install the tank float sensor there. I made a doubler ring with nut plates on it, split it so it could be fit into the hole, and riveted it on with lots of proseal.
Then, I went inside the tank through the normal end hole and installed the deflectors to keep the flop tube from getting hung up on the stiffeners, and installed the flop tube itself. Then, I closed up the tank.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
