There is no difference in torque for tension vs. shear. The shear torque you see in the tables is for "shear nuts". These nuts are thinner and therefore will not tolerate the same torque as full nuts. Even though the spar bolts are indeed in shear, they should be torqued to the full torque value.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
