01-06-2010, 06:43 AM
Compliance to Service Bulletins
I purchased a flying RV-9A in June last year. I was told which of Van's Service Bulletins, Letters and Notices and Revisions had been done and confirmed they were shown in the log book. However, there are several applicable items that have not been done. I will have all but a couple of minor items done this winter. Will all of these fixes need to be done prior to my next annual in June? I will be using a local A&P mechanic to do my inspection. Will he treat all of these items like AD's for certified aircraft, or are they considered voluntary or advisory? I would like some input from other members of this board before discussing it with my mechanic. Thanks for the advice.
01-06-2010, 07:04 AM
Service Bulletins are not mandatory, but you would be foolish not to comply with them. Depending on the A&P, he may not be aware of the complete list of SB's. You should have a copy of all applicable SB's and AD's for your mechanic. He'll give you good advice about what you should do.
Tony Phillips
N524AP, RV 9 (tail wheel)
01-06-2010, 08:49 AM
Van's service bulletins are not mandatory. Ill even go a step further- some of them are downright unneccesay. You need to find an A&P who is knowledgeable about homebuilts, and Vans in particular, to help you decide how to procede.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
01-06-2010, 11:10 AM
SB's optional?
I agree with Jeff, some may be unnecessary.
Still, if you insure your plane, and have ANY kind of claim, adjusters that are used to dealing with Certified A/c accidents are no doubt going to look for SB compliance, and wave them in your face when it's time to pay up!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
01-06-2010, 01:13 PM
VAF Moderator / Line Boy
OK, I am just curious, because this is brought up now and again - does anybody have FIRST-HAND experience with a claim being denied because an SB was not complied with on their aircraft? (Not "I had a brotherin law's second cousin's gardener what had a friend who....  stories.....)
I just want to know if this is a real problem, or a theoretical one, that's all!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-06-2010, 01:53 PM
I'll even go further..some of them are downright stupid. Like safetying the B-nut on the tank pickup.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
01-06-2010, 05:20 PM
Bob,
I was being diplomatic but you are spot on. The fuel pickup one was stupid and I kick myself for complying. The mk1 FAB mod is a close second on the scale. They both appear to be legal CYA rather than well though out legitimate solutions to real problems. As a result, I will never again perform a Vans SB without giving some serious consideration to it first.
YMMV.
Jeff Point
Milwaukee
01-06-2010, 06:43 PM
OK Nomex is on
Why didn't you like the fuel pickup sb? I did it during initial construction with my QB tanks, and it looked like a good idea to me. If the nut loosens, or the pickup tube moves, it looks like you could easily run out of fuel prematurely.
Maybe I just need that glider rating...
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
01-06-2010, 07:01 PM
Fuel Pick Up SB
I believe they had one off field incident "reported" where the claim was the pick up rotating when the B nut for the fuel line was tightened on the bulkhead fitting. I guess, if you did not tighten the assembly properly it could rotate. That was enough for Vans to CYA.
I guess it could happen, I have never tried to do it on purpose, but maybe. I did it as it came out just before my wings went on and was an easy "fix?".
Obviously the accident aircrafts fuel system was not tested properly prior to the first flight or the alleged rotated pick up would have been discovered very easily.
Vans has to CYA on a lot of stupid things and it only takes one.
Other SB's like the Tank Support slotting is only a recommendation based on the potential of the tank breaking apart if the wings where sheared off. Not sure any of that was based on a real situation or not.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
01-06-2010, 08:00 PM
Its silly because if the nut is properly tightened, its not going to come loose. The SB could have said to check to see if it was tightened, and left it at that. After all, there are many B-nuts in the fuel system, why not safety the rest of them?
I also believe that safetying the oil filter is silly also. If the filter is loose enough to rotate, it will be leaking profusely.
N8155F C150 flying
