01-20-2006, 06:25 AM
I need a new compressor. What to get?
My 22 gallon oilless Campbell Hausfeld compressor died last night. I'm a little mad because it was only 3 years old. But, at the same time, I always wanted a larger and hopefully quieter one.
Any suggestions?
John Michael Coers
90780
Fuselage
01-20-2006, 06:52 AM
01-20-2006, 07:01 AM
I second Jeff's opinion. It's a great compressor! Sears usually has sales so watch for it. I even might get another one once I take this one to the hangar.
01-20-2006, 07:07 AM
link
For anyone like me that couldn't get Jeff's link for whatever reason, search for Item # 00919541000.
Brian
01-20-2006, 07:30 AM
oiled compressor
not sure what size you are looking for, but an oiled machine will likely provide better service. not sure what make mine is. it's red. maybe C-H. don't recall. but I would endorse use of one that has oil lubrication. I use Mobil 1 in mine.
james kleen
savannah
RV8sp - RV3
01-20-2006, 07:56 AM
Right now I'm considering a Ingersoll Rand 60 gallon 5hp 2 stage compressor from Tractor Supply for 999.
Any opinions on that one?
Thanks for the quick replies so far!
John Michael Coers
90780
Fuselage
01-20-2006, 08:03 AM
If possible, get one of those large 60 gallon 240 Volt standup oiled machines from Lowes, Home Depot, etc.
They'll run airtools such as diegrinders with cutoff wheels & scotchbright pads, without running out of steam, and work much better for painting too. I went for years with a 30 gal compressor, but had I known, I'd have gotten one of these, much earlier.
01-20-2006, 08:07 AM
I was typing my reply before seeing this. I'm certainly in favor of the 60 gallon compressors. Mine is a cheaper Kobalt from Lowe's, which was in the $500+ catagory, but does an excellent job.
01-20-2006, 08:12 AM
I've heard the Ingersol Rand GarageMate is exceptionally quiet. Vertical tank, belt driven, 120V, oil type.
I'm wavering between the Craftsman mentioned and the IR.
01-20-2006, 08:23 AM
Ok, this may be the one:
Craftsman Professional 80 gal. Air Compressor, 5.5 hp, Vertical, 2-Stage Pump w/Splash Lubrication
It's on sale at Sears for $819. The guy on the phone says it's really a 7hp, the internet has the hp wrong.
A 2 stage oil lube would be quieter, right?
John Michael Coers
90780
Fuselage
