Rudder Hanging
All,
The plans give very specific dimensions (in 64ths) for how far the rod ends in the rudder should be from the front of the rudder spar. I assumed these would be starting points and some minor adjustments would be necessary. However, when I set the top and the middle rod end into the vertical stab I find the lower rod end off by quite a bit. Probably on the order of a quarter to a half inch. I am not even sure I could screw the bottom rod end in far enough to work.
Also, I notice that the distance between the rudder and the vert stab is getting wider as I measure from the top down. This is true even between the top and the middle rod end. I wouldn't think that should be the case, although I don't know for sure.
So, the question... Did you guys find the dimensions given on Drawing 7 for the distance between the rod ends and the front spar of 51/64, 59/64, and 1 and 3/64 to be somewhat close? Did any of you have to make major adjustments here?
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
