I'm working on the aileron practice kit and have a few questions. I'm not sure what I am building...it is Figure 1 on the first page. You rivet a 11" piece of angle to a 2 1/4" plate, which is also riveted to a 2 1/4" plate. The pic of it is below.
Anyway, it calls out for (12) #30 holes which will be filled with (4) AN426AD4-4, (6) AN470AD4-4, and (2) MSP-42 rivets.
Since the angle piece is a bit thicker, should it be countersunk?
When I dimple the thinner top piece, do I use the 1/8" die because I am using size 4 rivets?
That's what I did and there are some gaps between the pieces. I don't know if this is a technique problem or what. For now I am using a hand squeezer and I'm wondering if that is the problem.
