Old 01-01-2010, 01:46 PM
PaulStrickland PaulStrickland is offline
Default "rivet length" - or - "first big mistake"
Super excited to have finished the first half of the horizontal stab on my -9A today - until I realized that I riveted my HS-904 ribs to the skin using a slightly long rivet.
I used AN426AD3-4 instead of AN426AD3-3.5
Is this difference in length a big deal / do I need to drill them all out??
Old 01-01-2010, 01:56 PM
Cfrisella's Avatar
Cfrisella Cfrisella is offline
I think you'll be fine. Do they look pretty?
Old 01-01-2010, 01:59 PM
videobobk's Avatar
videobobk videobobk is offline
Longer rivets are just harder to drive, so if they look good, you did good. Build on--it's just an airplane!
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 01-01-2010, 02:07 PM
Most are pretty, a few are average, I drilled out & re-pounded the ugly ones (and one became a 4 but you can't really tell)
The skin around the center nose rib is all smiles, but I came up with a way to avoid that on the 2nd half and I've read that most people pay a little extra for bodywork around that area anyway...
Thanks for the help guys.
Old 01-01-2010, 04:32 PM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
Thumbs up
Wow, if that's your first big mistake you're doing OK! Try drilling holes SMALLER after you've drilled them too big! Now that's a big mistake.
Clay "Cookie Monster" Cook
Old 01-01-2010, 05:28 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default no problem
You will find that the Vans rivet call-outs are often a bit short. Use them as guidance, but if you put the rivet in the hole and it looks short (or long) - change to a different rivet. Happens all the time.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 01-01-2010, 06:36 PM
terrykohler terrykohler is offline
Default How do the shop heads look?
If they look alright, build on. The length of the rivet used in each application is determined by the ratio of free length to shank diameter. Too short and you don't have enough material for a decent shop head. Too long, and the shank tends to buckle rather than upset. As long as they're not buckling, you're good to go.
Terry, CFI
RV-9A N323TP
Old 01-01-2010, 09:54 PM
aarvig's Avatar
aarvig aarvig is offline
Posting pictures would probably help everyone form a better opinion of the situation and allow us amateurs to have a learning experience!
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 01-01-2010, 11:18 PM
Flying Scotsman Flying Scotsman is offline
If it's much too short or too long, you'll usually know it when you see it. For those "not sure" cases, we use this:
http://www.averytools.com/p-70-rivet-length-gauge.aspx
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
