Old 03-23-2010, 04:04 PM
RV4 N21471 RV4 N21471 is offline
If you check with the FAA, you will find they do not differentiate between experimental, and certified in regards to A.D. compliance. Any aircraft with an N number must comply with the A.D.
Old 03-23-2010, 04:34 PM
erich weaver's Avatar
I cant figure out why anyone would want to have ECI do the cylinder rework when the AMOC hasnt even been approved by the Feds yet. Seems like both the customer and ECI are asking for trouble and more delays by going this route. I would think that you would want to either wait for the Fed blessing of the AMOC or just buck up and pay for new cylinders. No?
erich
Old 03-23-2010, 05:55 PM
TomVal's Avatar
TomVal TomVal is offline
Default New vs Repaired
erich
I ordered new cylinders today.
Regards,
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 03-23-2010, 06:08 PM
Low Pass's Avatar
Low Pass Low Pass is offline
You sure about that? Who told you this? I've found that many feds are not versed on experimental amateur built rules.
Bryan
Houston
Old 03-23-2010, 06:21 PM
Put in a call to FAA Law Division in New England, and ask for yourself.
Old 03-27-2010, 02:46 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Exclamation Advisory Circular 39-7C
FAA Advisory Circular 39-7C, Section 8 Applicability of AD's:
Unless specifically stated, AD's apply to the make and model set forth in the applicability statement regardless of the classification or category of the airworthiness certificate for the aircraft.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 03-27-2010, 03:50 PM
newtech's Avatar
newtech newtech is offline
Originally Posted by DAGO View Post
I just got off the phone with Jim Ball at ECI. One of my questions was, even with repaired cylinders, until the FAA approves the repair, are we still tied to the inspection requirements of AD 2009-26-12? His response was, ?Your engine is in the experimental category?.? I guess you could read between the lines on this one.
Somewhere I heard, I think from JB, that the re-worked cylinders would have new serial numbers. The new S/N's wouldn't be on the AD so the AD wouldn't apply. Check with ECi but this was my understanding.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 03-27-2010, 03:55 PM
TomVal's Avatar
Thanks for the post Steve. I decided to go with new cylinders. Today, I pulled cylinders 1 & 2. They both look great. Tomorrow, I'll pull 3 & 4 then send the whole lot to ECI for exchange.
Regards,
Tom Valenzia
RV8 (Sold)
Old 03-27-2010, 04:09 PM
KirkGrovesRV8 KirkGrovesRV8 is offline
Steve I believe you are right JB told me my reworked cylinders would get new serial numbers
All the Best ;-)
RV-8
RV-9 once the kids are older
Old 03-27-2010, 05:28 PM
Walter Klatt Walter Klatt is offline
Default Any bad EXP cylinders
I am wondering if any of the newer tapered fin EXP cylinders had this problem? Were any of these manufactured in the AD serial number range?
Walter
