Old 04-14-2010, 01:55 PM
az_gila's Avatar
az_gila az_gila is offline
Post Which should...
Originally Posted by lostpilot28 View Post
I hear what you're saying, Gil. I was only stating that I believe ECI has a great product, and my 2 seperate experiences with both ECI and AERO were very good. It does sound like a PR nightmare for ECI, but reading AERO's letter doesn't make me doubt the quality of their product.
...probably worry other distributors more than proof of poor quality parts...
I too have dealt with both and use ECI parts - it's a matter of how ECI treats their distributor chain...
What would you think if you were selling ECI parts?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-14-2010, 02:28 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
I agree that it's certainly not good customer service on ECI's part. If AERO's letter is telling it like it happened, then that's a pretty crappy thing for ECI to do.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 06-26-2010, 07:02 AM
Jim Kiloh's Avatar
Jim Kiloh Jim Kiloh is offline
Default Any updates
There was a new thread started by 'Gasman' a few days ago asking this same question but no one replied so I thought I would try this thread.
What is the average turn around time are you experiencing for getting the re-work done on the ECI cylinders?
When I phoned them I had 75 hrs on the engine I was told to keep flying and do a compression check every 50 hrs. The reason I believe was because they were so backed up with returns.
What are you guys experiencing now?
Jim K
Cypress, TX (T51)
RV 7A-
O-360-Dual P mags-GRT EFIS-Tru-Trak AutoPilot
Flying as of 9/7/08
Finally painted 2/8/13
Old 06-26-2010, 07:42 AM
tc1234c's Avatar
tc1234c tc1234c is offline
I don't know about now, I sent mine in on Feb 5th (arrived at ECi on Feb 10th). I did not hear from them until 3/18 when the rework order was logged in. On April 21 they have finished 3 sets of cylinders and promised to finish the rest 63 sets by May 15th (news release posted on VAF). Soon after I got a phone call telling me that all four of my Group A cylinders were "bad" and they are sending four new ones to me free of charge. I received them on May 6th.
I was surprised by two things: 1. so few cylinders were sent in for rework (3+63). 2. it took so long for them to begin the process and so quick to finish them all. I was not pleased for the down time (three months) yet am happy that I have all four new cylinders.
Ted Chang, VAF #681
2018 Due paid
Old 06-26-2010, 09:02 AM
erich weaver's Avatar
Based on the Amy laboda's article in the August issue of Kitplanes, it looks like the alternate means of compliance ECI was going with is not legal in FAA's view - even for experimental aircraft. At least not until FAA approves the AMOC, and who knows how long that will take. Hope ECI isn't driven into bankruptcy by having to replace all these cylinders.
Erich
Old 06-26-2010, 10:23 AM
az_gila's Avatar
Exclamation There may be problems with their approach...
Erich
This came from an e-mail from an engine rebuilder when it was first announced. I won't give names since it hasn't been cleared with the author, but the points seem reasonable...
The end result of the barrels not being correctly clocked is that the
intake tubes and exhaust will not fit and the push rods and their
shrouds will not perpendicular with the camshaft. This problem comes
about as a result of changing the cylinders manufacturing order of
mechanical operations. Normally new barrels are screwed into the heads
to a specific torque and THEN the flange of the cylinder is drilled for
the mounting studs and further machined which assures the correct
clocking of the barrel to the head when everything is screwed together
tightly.
In order to do the intended AMOC they will be measuring the male threads on
an old barrel that has its flange already drilled and machined and the
female threads in the cylinder head. They then select a barrel with threads
the correct size to allow a proper interference fit with the female threads
in the barrel. During this operation the head must be screwed in at a
specified torque and at the same time have the parts correctly clocked in
relationship to on another when its all done, GOOD LUCK! Any mistake in the
selection of barrel to be matched with the head or miss clocking of the head
on the barrel makes for a piece of junk.
Gil Alexander
Old 06-26-2010, 05:03 PM
jrs14855 jrs14855 is offline
Default ECI
I don't have all the details about the AERO/ECI feud. What I do know however(lawyers getting involved) has caused me to buy engine parts from sources other than AERO. My current favorite is Dart Aircraft in Waco, TX. Excellent service and prices. I just don't think that ECI has the deep pockets to handle the cylinder debacle in a more timely manner. A reminder about Lycoming-they have had more than their share of problems over the years including, like Continental, some major crankshaft problems. Lycoming is strictly a sales/service organization. ALL Lycoming parts are made elsewhere. I would hope that most of ECI's parts are made inhouse and that would cause me to favor ECI. I personally have no problem with ECI parts.
Old 06-30-2010, 11:39 AM
Fallalloveryou Fallalloveryou is offline
Default ECI Rocks
They seem to have a different policy for outside US. I boaght new cylinders on my own before I took the engine apart so I would have minimal down time.
When it came time to notify them they just said, send photos of the old cylinders with the rockers arms destroyed and a copy of the receipt I paid for the new cylinders and they would send a refund ck to me, which they did.
Rick from Canada
Old 08-07-2010, 10:33 AM
61DX 61DX is offline
Default Group A Cylinders
I just found out that I have four group A cylinders on my O-320. Although I trust the cylinders, I don't like the idea of compression tests every 50 hours.
Has anyone had thier group A cylinders reworked? Did this ever get approved as AMOC? I notice that thier MSB 09-3 (cylinder rework) is now gone from the website.
If not rework, has anyone gotten replacements or discounts on new cylinders? Would appreciate any insight before I call ECI next week.
Old 09-02-2010, 01:00 PM
bobdobbs bobdobbs is offline
So I have a cylinder that does not have P/N AEL65102, but has a S/N in the "B" group.
I have been told by ECI that the cylinder (A titan EXP cylinder), is not recalled and therefor not eligible for replacement.
They are offering to rework the cylinder as per their proposed AMOC at no charge.
I note that the continental cylinders in this range also have an AD against them.
Any opinions on whether I should go for the proposed AMOC rework, buy a replacement outright or since the cylinder does not have a AD assume there is no problem?
