Old 12-31-2009, 07:25 PM
kevinh's Avatar
kevinh kevinh is offline
Default Removed carb, do I need a new gasket?
Hi ya'll,
I'm looking for a bit of advice.
I removed my carb to do the float SB (along with the rest of my annual). When I went to go put it back on I realized I forgot to order a new gasket that goes between the engine and the carb. Do I need a new one? The one that's there has been on the engine since I first flew it in 2005.
I'll happily order new gaskets from Van's if that is appropriate, but otherwise I'd be eager to get the carb back on this weekend.
Happy new year!
Kevin
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 12-31-2009, 07:39 PM
Kyle Boatright Kyle Boatright is online now
Originally Posted by kevinh View Post
Hi ya'll,
Happy new year!
Kevin
Unless you damaged it when removing it, you should be OK. I've successfully re-used that particular gasket before after a similar period in-service.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-31-2009, 07:46 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Pick up a roll of gasket material and carve a new...
Hi ya'll,
Happy new year!
Kevin
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-01-2010, 05:39 AM
pierre smith's Avatar
Default Yep....
....what Reiley said
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-01-2010, 12:22 PM
kevinh's Avatar
duh - make a new one, I should have thought of that. Thanks all.
