Old 12-31-2009, 05:45 PM
trib trib is offline
Question Cowl insulation adhesive question
Well I have almost 9 hrs on N621TR and it's flying beautifully (since 12/12). Plan to remove the cowling after the next flight and change oil. Also plan on RTVing any baffle gaps I can find. At 2300 rpm cruise my CHT's are 346-350F and I'd like to see that a little lower, particularly with the winter OAT's.
The insulation on the lower cowling has come loose in one area. It was self-stick adhesive. Can anyone recommend a good high temperature adhesive to glue the insulation to the cowling?
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 12-31-2009, 06:01 PM
Bavafa Bavafa is offline
Congratulations!
I used fiberfrax coating cenment, of course the insulation is also firberfrax. Its been about 9 months and 145 hours and so far holding pretty good. You can not feel the temp on my lower cowl at all, excellent for what it does.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-01-2010, 08:48 AM
flion's Avatar
flion flion is offline
If you're using the aluminized material that self-adheres, I went around the edges of mine with a little epoxy at the same time I sealed the rest of the inner surface. With the edges sealed down it has shown no tendency to peel up.
EAA Technical Counselor #5357
Old 01-01-2010, 10:55 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Regular 3M spray adhesive should do it. Or whatever is on hand... contact cement, or other, but not Elmer's school glue or paste. ;-)
Then a little ProSeal in a baggie does the edges nicely. Or Red RTV looks nice too.
The hardest part is getting the oily dirt off first.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
